Message 1 of 5
Is interleaved on Permanently
I've been out on an interleaved setting by openreach engineer will it automatically go to fast path or is this permanent
4 REPLIES 4
Message 2 of 5
Re: Is interleaved on Permanently
Can anyone help?
Message 3 of 5
How do I check the status of my line fast path or interleaved thanks
Message 4 of 5
Your posts shows interleaved and once set unlikely the DLM will change back to fast.  In theory the DLM  should if !ine stable with few errors move back to fast but that never seems to happen
Message 5 of 5
Thank you
