Message 1 of 3
Is the fibre cable "size" the same for 150/500/900mbps speeds?
I'm about to order full fibre, but haven't quite decided which speed to go for.  I assume there is only 1 size of fibre, then they throttle back or turn up the speed, depending which contract you go for.  Am I correct in my assumption?  I don't want to go for 150mbps then have to have a different cable installed if I upgrade speeds later.
2 REPLIES 2
Message 2 of 3
Re: Is the fibre cable "size" the same for 150/500/900mbps speeds?
There is only 1 fibre cable regardless which package you choose
Message 3 of 3
The speed is effectively throttled by software to ensure you're only recieving what you pay for. Saying that, we're on an Openreach connection and paying for 500mbps but I normally get around 500-600 mbps. The highest I've seen is 750-ish
