Message 1 of 6
Is there a problem www.speedtest.net?
Ages ago the Gurus on here recommnded I use www.speedtest.net as the BT speed test was bust.  For the last few days the internet has been very slow.  So I tried www.speedtest.net several times and the upload showed as zero.
5 REPLIES 5
Message 2 of 6
Re: Is there a problem www.speedtest.net?
Message 3 of 6
From personal experience, this website can be a bit flakey with its results.
Message 4 of 6
Hi @Keith_Beddoe & @NigelB72 ,
Given that you are the only two that replied it leads me to think that the problem with speedtest.net is more likely to be with me then.
Message 5 of 6
no problem for me - been using the actual speedtest windows app - suggest you try this and see if you still have problems.
Message 6 of 6
It's working for me.  🙂
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
