Message 11 of 46
Re: Issues with changing to FTTP
Clearly you weren't dealing with millions of customers as Openreach are, a whole different ballgame. I'm afraid it is not realistic to expect every installation to be individually surveyed and discussed beforehand.
Message 12 of 46
Every address is surveyed externally before the FTTP network is provided , there is even a summary of the type of installation and any likely difficulty the address will have available on line , so there is no ‘turning up and winging it’ , obviously some things can’t be predicted such as an external duct to the home being blocked and not discovered until an attempt to use it is made but generally any difficulty is noted in advance and the appropriate installation method (one or two stage installations ) used .
If every address was pre inspected internally before the the actual installation is programmed then the costs of that visit need to be paid for , adding unnecessary costs to the ISP when it will be a tiny percentage where this pre visit is useful, no Alternative Network provider does this , if they did the added costs would make them a less financially attractive proposition, requiring just Openreach to do this and bare these costs ,  when they already have more costs than the opposition would be inequitable, what’s more if no agreement can be reached as far as the work needed within the home , the order can always be cancelled, no one has ever been held down by Openreach while some work was completed against their will, if householder doesn’t agree the work isn’t done , can’t really be any simpler than that.
As fas as the apparent imposition of adding  a FTTP installation to the (necessary) DV migration, although it may not look like it , the FTTP part can be refused , the DV migration still taking place, albeit possibly rescheduled , although anyone doing that is simply delaying the inevitable, no one can refuse FTTP forever , that point in time  is not here yet though , and won’t be for quite a few more years .
Message 13 of 46
Do you know please how far off the wall the ONT projects when surface mounted?
Message 14 of 46
Message 15 of 46
In addition to the link @licquorice has given in previous post, here more technical information (provided to suppliers) about other makes and models Openreach use for their ONTs
https://www.openreach.co.uk/cpportal/content/dam/cpportal/public/images-and-documents/home/help-and-...
Message 16 of 46
The latest Adtran, (a 611 I believe), installed for me 4 months ago sticks out 2.5cm
Anonymous
Not applicable
Message 17 of 46
Putting things in perspective
Openreach sub contracts
Each sub contractor is expected to fully install Full Fibre within 2-4 hours
Sub contractors are paid by the job.
That's why you often see rushed and botched installations
You'll probably find what you want and what you get are not the same
Message 18 of 46
That's what concerns me.....:-(
Message 19 of 46
Bear in mind you only hear the bad news on forums, not the good news.
Not all installs are sub contracted.
Message 20 of 46
And even if they are sub-contracted, they’re not necessarily poor.
Mine was done by a guy from Quinn’s and he did an excellent job.  (And, trust me, as ex-trade I’m not easily impressed).
