Message 31 of 31
Re: Low upload speed
@Danedin1 Considering you've had more than multiple openreach engineers out for over a year and a half and now they tried with technical help designed for your devices and none has worked, then you have to ask yourself is fibre broadband for you?
It's a serious question because every time you are getting engineers it means another customer isn't.
