Message 1 of 3
MDU install
I am building a small block of flats
I want to future proof them as in 2026 FTTP will be available.
The OpenReach will come in the front under the post box.
Can you please advise what cabling should I run inside the building from the postbox to each flat.  Is it EZBend optical fibre.
do I need to terminate the ends of the fibre cable at each end? Or just leave it hanging for when the OpenReach arrives?
2 REPLIES 2
Message 2 of 3
Re: MDU install
You need to approach Openreach ‘newsites’ department, anything you install yourself not supplied by OR is not likely to be used
Message 3 of 3
Re: MDU install
@Anjai
See https://www.openreach.com/help-and-support/developers
This has nothing to do with BT Retail, who operate this forum.
