Message 1 of 11
Modem Settings for Billion Router
Hi all ive purchased a billion 8200AX could anyone confirm the correct settings for VDSL 2.
Ive posted a picture of the settings page.
Thanks.
10 REPLIES 10
Message 2 of 11
Re: Modem Settings for Billion Router
I managed to get the router working boy this thing is great. The line speed has increased 5m and it gives more information regarding the DSL and what's going on. The sync speed has gone up by 10.5.
Message 3 of 11
@roco1970
The other thing to do would enable G.INP which might give you a bit more downstream speed depending on the make of fibre cabinet you're attached to.
Message 4 of 11
Do you have a before/after of your stats? This fills me with hope that purchasing a 3rd party router to replace my bt smart hub 2 could increase speeds on my fibre 2 package 🤞
Message 5 of 11
With the home hub 6.  sync 55mps down and 9 up with the billion........
Operational StatusVDSL2-17A Annex B,SHOWTIME.
Upstream Speed11452 kbps
Downstream Speed59917 kbps
You can also tinker with the SNR it really annoys that miserable little green box down the road lol.
Im very pleased with the router. Im using it as a modem only and wifi duties Asus AX88 its wifi performance is brilliant!
Message 6 of 11
If you enable G.INP as previously mentioned you won't need to tinker with the SNR (providing not an ECI cab)..
Message 7 of 11
3dB margin has nothing to do with G.Inp 😉
Message 8 of 11
I thought with Billion routers you could only tinker with adsl  snr levels not vdsl.
Message 9 of 11
It does affect it i can confirm
Message 10 of 11
Didn't say it did.
