Message 1 of 5
BT smart hub
I've just received my BT smart hub but there's is no wan port only 4 lan ports ???
4 REPLIES 4
Message 2 of 5
Re: BT smart hub
Advanced settings > Broadband > Internet set full fibre FTTP mode to on. Changes LAN port 4 to WAN
Message 3 of 5
Re: BT smart hub
@Stephen11
You only use the WAN port if you've got FTTP otherwise it's the Broadband port at the other end of the unit.
Message 4 of 5
Re: BT smart hub
Yes just got fftp
Message 5 of 5
Re: BT smart hub
@Stephen11
In which case the SH2 supplied should have had port 4 clearly marked as WAN.
If it's an older SH2 then it might need a firmware update to be able to activate port 4 , but without a connection you won't be able to do that I guess.
I know that originally the WAN port couldn't be changed back to a standard ethernet port , not sure if it was always a case of port 4 being the WAN port though.
