Message 1 of 8
Modem power supply
Can I open a bt fttp modem and remove the power cable which in my case it appears is wired into a battery backup ?
I thought I was moving to ee and had a battery backup to my router removed from my account to allow this -
a red flag still shows on my account so ee need to write to openreach to remove this .
No one from EeOr Bt on the three hours of calls made so far mentioned this till today …
battery backup in remote areas with poor / no mobile signal was offcom recommended-once .
any advise on the modem please ?
7 REPLIES 7
Anonymous
Not applicable
Message 2 of 8
Re: Modem power supply
no this id not your equpment this is loaned to you this bt or EE property
Anonymous
Not applicable
Message 3 of 8
This all sounds a bit odd. Never heard of an ISP having to "support" a BBU. If it's what I think it is it's largely redundant anyway & can be just be bypassed by taking the power cable from the BBU, unplugging the ONT & connecting the BBU power cable in it's place. Maybe post a pic of what you have.
Message 4 of 8
Thank you
The power supply was provided by bt and is badged bt/ee
bt no longer support it .
ee don’t want it ether
It’s redundant
Message 5 of 8
It’s redundant anyway .not on my account Not used, just flagged up by Oprnvreach which prevents transfer - thank for your comments
Message 6 of 8
Message 7 of 8
Sorry can’t open the file
Message 8 of 8
Is your setup like this
