Message 11 of 13
Re: Mounting ONT on a conduit back box.
Just to show it is possible
My fibre comes from pole following my original copper at back of house and enters at the eves and into my loft conversion and then my ONT and CSP are mounted on my loft conversion internal wall
ONT  + internal CSPONT + internal CSP
Message 12 of 13
Thanks.
Obviously it can be done. It's just  matter of whether I can persuade Openreach to do it. On reflection the position of the ONT (first floor of a two storey house) is more important to me than how the ONT is mounted.
Message 13 of 13
@CUSTOMER49
my post was more about the fact that the CSP can be positioned in your home and not necessarily on your wall outside
