Message 11 of 15
Re: New SH2 arrived today - can I try it now?
No reason why not.
Message 12 of 15
Well the engineers have been today (MJ Quinn) and I couldn't fault their work.  Neat and tidy job, all up and running, and expected speed reached.
Is it possible to get a BT wifi extender for free?.  I don't rely on wifi for my main connections, but could do with a boost to the kitchen if I'm to invest in a smart speaker.  As looking at the phone, the signal is marginal.
Message 13 of 15
You can add on halo 3 with WiFi which will give to discs which help your WiFi coverage but not free   you can buy power line adapter that include WiFi and not expensive probably tplink the cheapest.  I cannot see BT giving them for free
Message 14 of 15
Thanks, I'll probably go for a 3rd party option then.  Be great though if I could have swapped one for the digital phone they sent me (I'm using my own), which I imagine is at least equal to the value of a disk (maybe).
Message 15 of 15
Any discs are part of the halo add on and not supplied on their own
