Message 11 of 14
Re: New installation of Full Fibre in Flats but speed capped at 100Mbps
Ok well thanks for the heads up - good to know it is possibly error and not some sort of restriction due to the location or something like that. I am close to the centre of town so not rural and my Father who lives 10 minutes away gets over 1000Mbps.
I will keep checking in with them every couple of weeks.
Message 12 of 14
The guy did drill through electrical cables so not internal lights in the common areas at the moment. Hopefully if there is an error it will be picked up by somebody somewhere. Perhaps once the whole complex has been finished.
Thanks for your help much appreciated.
Message 13 of 14
If the actual installation work isn’t yet finished, so testing/commissioning etc is needed it may be what’s shown currently is just a ‘holding’ status until the installation work is booked off as finished, that’s just speculation on my part though….as stated ,check again in a few days it may change, it could be you were a little too quick off the mark as far as trying to order
Message 14 of 14
OK - thanks - makes sense.
Appreciate the insight.
