Message 1 of 11
New router for FTTP
I was sent a new router for my change over to FTTP. But engineer asked if I received a ETH cable (RJ45) to connect NBN connection box to new router. I was never sent one so broadband is down who in BT can send me one ?
10 REPLIES 10
Message 2 of 11
Re: New router for FTTP
Its just an ordinary Cat 5 Ethernet cable, do you not have one somewhere?
I assume you have already been changed over?
Message 3 of 11
I'm a pensioner and all my devices are wi-fi. Why didn't BT or who ever supplied router provide a cable?
Message 4 of 11
BT normally send one in the post, as part of your order.
You are not going to benefit much from a fast FTTP connection if you only use wireless.
Has FTTP been activated and the copper connection disconnected?
Message 5 of 11
Yes copper removed changed over to fibre but No ETH cable to test if it works
Message 6 of 11
Cannot suggest anything apart from getting on locally, they are very cheap. Currys/PC World. Screwfix, Argos  etc.
If you look at your BT order, there should be a pending item for a short cable. If not, you would have to ring BT and ask them to send one, but its likely to take a while.
Message 7 of 11
It's really not worth chasing BT to supply this cable, they'll take ages to supply one and may not get aroud to doing so at all.
It's just a standard ethernet Cat 5 cable, readily & cheaply available in Currys, computer shops, B&Q, Screwfix etc.
Message 8 of 11
Message 9 of 11
You sure you're on the right forum, mate?  NBN seems to be an Australian expression.  I've never heard it used in the UK.  We call it an ONT.
Message 10 of 11
Yes you are right Optical Network Terminal
