Message 1 of 6
New to fibre 1
Hi, just had my BT fibre 1 installed .. says I am on full fibre speed boost for a few weeks .. tested my speeds to the hub am getting 149mb download and 31mb upload ..   connection  wired ..the cabinet is a few yards from my house.  As I am new to this are these speed OK ..
5 REPLIES 5
Message 2 of 6
Re: New to fibre 1
@dvdcks47
Full fibre does not come from the cabinet.
Do you have an Openreach Optical Modem (ONT) fitted in your house, which has a number of lights on it, like PON, LOS, Power?
Anonymous
Not applicable
Message 3 of 6
Re: New to fibre 1
That's exactly what you should get on Fibre 100. It's there as a tempter so that when the speed falls back to the 55/10 you signed up for, you'll want to upgrade.
Message 4 of 6
Re: New to fibre 1
Hi ..yes i have a small box in my house with various lights
Message 5 of 6
Re: New to fibre 1
Many thanks for your reply  and answer...
Message 6 of 6
Re: New to fibre 1
Then your speed is just fine.
