Message 1 of 9
No Internet all week, am I being lied to?
I've had no internet all week due to a supposed "major service outage" and the time for an estimated fix keeps changing. The lights on my hub are orange and have been since Monday morning but I haven't heard any other local people talking about it. My full fibre before was a bit spotty so it makes me think that there might not actually be an issue and BT are just gaslighting me. Surely it doesn't take a week to replace cabling due to "wear and tear"?
Very unhappy with the service.
8 REPLIES 8
Message 2 of 9
Re: No Internet all week, am I being lied to?
This site tends to be worth a look, (even though it’s run by Zen):
https://status.zen.co.uk/broadband/
Message 3 of 9
Absolutely nothing on there about my problem in Lancaster. The plot thickens....
Message 4 of 9
If your hub is orange it won't be a physical cable problem it will be an 'exchange' problem.
Anonymous
Not applicable
Message 5 of 9
What lights do you have on the ONT?
Message 6 of 9
All the same as usual. All but the far left one
Anonymous
Not applicable
Message 7 of 9
"Far left" doesn't really help as there are different models, what's it labelled?
But if everything is normal then I'd suggest logging on to the SH2 to make sure that FTTP Mode is still active, although I expect it to be purple if not. If it is active then try a factory reset using the pin hole on the back. It may need to be held for 20-20s until the LEDs flash. If you have DV phones then backup your contacts first.
Message 8 of 9
If the PON light is lit and steady ( not flashing ) then the network is fine , and whatever the issue is , doesn’t need Openreach to visit you , it could be a MSO , but it’s not likely
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/what-do-the-lights-on-my-bt-hub-...
Steady orange suggests a problem with the way your account is configured/set up , you need to contact them again
Message 9 of 9
Hmmm, everything was working fine until Monday, so I'd hope it's not an account issue. Again, Ive been told theres a local outage but no one I have spoken to locally is having issues either and it seems a long time for the reasons they gave for the outage.
