Message 1 of 7
Escalate repairs
After reading some other posts I see that some moderators can look into an issue and raise it as a complaint or shed some light. Appologies for the long bible below. Frustration is building over the length of time to resolve an issue.
From the get go I will highlight any contact with engineers or customerservice agents or BT employees in general has been great cannot fault them even though I have the ongoing temperamental issue the staff are great.
Complaint/Issue - speed reguarly drops down below the stay fast sometimes well below the stay fast. It will bounce back fir periods of time but no matter what is done to fix it keeps doing it. This  has been going on for "8 Years" stay fast speed is 26mb  common actual speed is below 5mb on fttc multiple engineer visits no resolution clearly a line issue it was even an issue prior to changing back to BT. But yhe issue starting to get to my whits end.
As the issue is temperamental sometimes by the time.an engineer either from BT or open reach comes out the speed is fine. On the phone they will see the speed drop, I think only twice has it been acting up while getting a face to face visit from BT or open reach. I appreciate that I was told as I repeatedly fell below the stay fast guarantee I could leave penalty free however what would that do except leave me with the same issue but new person to pay money for a service to that dont work.
House has been checked by BT and openreach with no issues. Line from house to pole had new end fittings put on and again at the cabinet with no change to the problem. I was hooked up to a new connection at the cabinet, new BT in house wall plug and router with no change.
One of the open reach engineers mentioned I seemed to be connected to a cabinet a fair distance away when there a cabinet closer and a pole in reach to that cabinet. And apparently I had either steel or aluminium phone cables which could also be the problem due to the age and possible degradation.
So my issue is why if there is clearly a line issue is nothing getting done to fix the issue.
I understand fully that open reach has now split from BT so probably makes things even more difficult but surely there should even be compensation from either open reach or BT for the lack of service provided or length if time to fix (i would prefer the issue was fixed than compensation, just to add). I have 5 kids/teens in the house, 26mb is barely enough to support their thirst for online connectivity so 5mb and below is soul destroying. Would rather it cut off fully . I get I can change provider but that's a pointless task for an issue with the line.
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Escalate repairs
Sadly, not any more.
If you have an analogue telephone service, try a quiet line test by dialling 17070, option 2 next time it drops. It should be near silent with no pops, clicks or crackles.
Message 3 of 7
We got moved to digital telephone service unfortunately
Anonymous
Not applicable
Message 4 of 7
Then all I can suggest is that you get BT to agree to termination of your contract, penalty free due to failing to meet the promised speed.  The order a new service with someone else, but an actual new service as in a second line. Once that's installed & hopefully working without issue, you can go ahead & cancel BT. Of course you could use BT for the second service if you wish. The down side to this is you may lose your phone number.
Message 5 of 7
A get the idea.. but why should I have to do that? Also I still have the same cable between me and the cabinet which is causing the issue (according to the engineer). As far as I can remember, the standard cable can support at least 2 lines, so to force a brand new cable for just between me and the pole out the back, I would need to order 2 new lines while keeping the bt one open for that plan to be of any use (at least thats how it looks in my head) then hope that the cables between the pole and the cabinet dont have capacity other wise I am just back to the same position I am in now but with 2/3 providers.
Anonymous
Not applicable
Message 6 of 7
You absolutely shouldn't "have to". But the alternative is to carry on banging your head  against the wall.
My understanding, & happy to b corrected, is that while the drop wire can support two pairs, you would have a completely separate connection back to the cabinet. Although I misread that the drop wire had been replaced, so it's possible that's still the problem.
Have you looked at a 4G or Starlink as a solution? Although I believe neither are great  for gaming.
Message 7 of 7
Hi @Cameron6951
Welcome to the community.
I completely understand your frustration. The best thing to do in this instance is to contact our Customer Support team to follow our complaints process.
This will be logged against your account and managed to a resolution. Please keep us updated with what happens.
Chris
