Message 11 of 14
Re: No Service Since activation/going live
On the bright-side, if you haven’t been the previous supplier’s customer for the last two years, I would think you’re entitled to a refund and possibly compensation.  Surely, it’s illegal to be taking money out of someone’s account when they are not your customer?
Message 12 of 14
@gregkr
it was the fact that you had a connection problem before moving to BT and not subsequent to your move whereas your initial post suggests problem only happened since you decided to move to BT
Message 13 of 14
The LOS ( loss of signal ) light on , indicates that there is no ‘light’ being detected at the ONT , if there was some storm damage near the pole it’s possible that the fibre dropwire has been damaged ( hence the LOS ) however if this storm was after the original problem it may be unrelated…however the obvious place to check is at the pole top and if that needs a hoist to access the pole , then that’s the way it is .
TBH , I’d be concerned what the problem was with the previous ISP , and why they were unable to fix the problem .
Message 14 of 14
Just an update. Looks like openreach had to run a new cable between bt posts once thats was done I got a working internet with in a day. Thanks.
