Message 1 of 4
Ont power cable
Hi, I’ve just moved into a property and had my internet activated. Unfortunately the thing pictured is missing a power cable. Which power cable should I buy?
3 REPLIES 3
Message 2 of 4
Re: Ont power cable
there is no picture
if ONT power supply missing then I would contact your ISP and get them to send you a new power supply or more likely get openreach visit
Message 3 of 4
Re: Ont power cable
Ah - thanks for the quick reply. My mistake picture added now.
Message 4 of 4
Re: Ont power cable
It is not just a straightforward power supply so I would phone your ISP if BT 03301234150 and report problem and probably get openreach visit to fit power supply
