Message 1 of 6
Openreach customer service point installed outside new build property
Hi, I am preparing to move into a new build house and struggling to find internet options available ( haven’t moved in yet) but I went there today and noticed this on the house. What is this? Is this a good thing and does this mean I should be able to get fibre? Thanks pic attached
5 REPLIES 5
Message 2 of 6
Re: Openreach customer service point installed outside new build property
That is CSP for your fibre connection. You should see something like this inside which is ONT- fibre modem
Message 3 of 6
Thanks for reply will check for that indoors if It has it would you say I would be able to get good fibre internet?
Message 4 of 6
The box outside and the ONT @imjolly posted in previous post means it's full fibre.
See more about full fibre:
 https://www.openreach.com/fibre-broadband/ultrafast-full-fibre-broadband
https://www.bt.com/broadband/full-fibre-learn
Anonymous
Not applicable
Message 5 of 6
Note that a new build may hide the ONT away in a cupboard, possibly with a small patch panel to feed ethernet from the router to different rooms.
Message 6 of 6
As you are posting on a BT consumer forum , when you find the FTTP ONT inside the property, and as said , could be  inside a cupboard or somewhere not necessarily obvious ( under stairs storage area , or bedroom cupboard etc ) or simply mounted in an electrical pattress box in an immediately visible location , if the PON light is lit and steady  ( not flashing ) then the Openreach ‘work’ is complete and provided the address information has filtered down to the ISP ordering portal, you should be able to raise your order with BT , speeds upto 900Mb are available with FTTP , soon to be 1.8Gb.
