Message 1 of 2
Openreach installing ONT
Will Openreach instal the ONT
if I leave BT . If they do any idea of cost?
If I stay with BT is the installation FOC?
1 REPLY 1
Message 2 of 2
Re: Openreach installing ONT
Will Openreach Install an ONT if you leave BT?!?!
They’ll install an ONT if whatever SP you chose uses the Openreach Fibre Access Network.
As to the Installation Cost. That’s up to whichever SP you go with.
Openreach don’t directly charge you for one, they charge their Customer, the SP.
