Message 1 of 5
Does anyone know what ONT's Openreach are currently installing
Wondering how many ethernet connections the boxes have and if I can bypass the smart hub and simply go straight into the ONT with ethernet for the PC
4 REPLIES 4
Message 2 of 5
Re: Does anyone know what ONT's Openreach are currently installing
There is only 1 connection on the ONT.  You can connect PPP0E from pc to ONT. If you have digital voice then you need to use SH2
Message 3 of 5
Thanks, I'd seen on the BT page they said there were 5 types of openreach ONT's and some had more than one LAN
https://www.bt.com/help/broadband/whats-an-openreach-modem-ont
Message 4 of 5
The 4 port devices are used to support 4 discrete services, not 4 LAN ports from one service. The ONT is a modem, it doesn't have routing capability.
Message 5 of 5
That’s outdated.
Openreach no longer supply Huawei ONT’s at all.
Only ECI, Nokia and Adtran.
They’re trialing a 4 Port Nokia ONT.
