Message 1 of 3
Optical network terminal
Is it possible to get a flush wall mounted ONT suitable for a BT halo install?
2 REPLIES 2
Message 2 of 3
Re: Optical network terminal
No, Openreach don’t have Flush Mounted ONT’s.
New Sites do get a little ONT Case, which look OK but they don’t normally fit them on Brownfield Sites.
Message 3 of 3
Thanks.
