Message 1 of 3
Orange Light Smart Hub 2
Folks
I've done a factory reset on the Smart Hub 2. However it's now just a solid orange light.
Any ideas how to get it back running again?
The worst thing is, I've no mobile signal at home. I'm currently up a hill near my house to post this!
2 REPLIES 2
Message 2 of 3
Re: Orange Light Smart Hub 2
If it is flashing orange it means it is trying to connect to the Internet, a solid orange means it can not connected to the Internet. Normally it should only take a few minutes to re establish the connection after the factory reset.
See link
What do the lights on my BT Hub mean? | BT Help
Why did you carry out the factory reset, was there a problem?
Message 3 of 3
Thanks but got sorted. When I reset I took out all the cables.
When I rang BT they told me the red cable (LAN?) had to be in slot four.
Thanks for taking time to reply.
