Message 1 of 2
Orange light on by hub 2
By hub 2 stuck on orange. I’ve tried to follow advice on ‘my bt’ app but I just can’t get it to work.
any advice??
1 REPLY 1
Message 2 of 2
Re: Orange light on by hub 2
Nothing you can do locally, you need to report the fault to BT.
