Message 1 of 2
Purple flashing light after checking wire connection
I’ve just set up my new BT hub and there a purple flashing light and I did what the manual said and checked the wire connections and so I made sure it was plugged into the filter BT provided but it is still flashing, what should I do ??? on a side note I only have one socket in my wall outlet if that changes anything
1 REPLY 1
Message 2 of 2
Re: Purple flashing light after checking wire connection
When did/does your service start? Do you have dial tone at the socket?
