Message 1 of 8
Purple flashing on smart hub
Hello, I am having problems with my smart hub continuously flashing purple.
I have checked the cables and all of these are connected properly and have rebooted the hub. Unfortunately, nothing has changed and as I do not have a landline I cannot check for noise.
Any recommendations on how I could fix this/ what the problem could be?
Should I factory reset the smart hub?
7 REPLIES 7
Anonymous
Not applicable
Message 2 of 8
Re: Purple flashing on smart hub
Assuming you don't have FTTP, if you have a modern master socket, remove the front panel & plug directly into the test socket at the back. You may need a microfilter.
Message 3 of 8
Thanks, my smart hub manager says fttp mode is turned on so I’m assuming I do have it. I am a tenant and do not pay for my broadband so not sure of all the details.
Is the modern master socket the primary phone socket? I would need to unscrew the panel I think.
Is there anything I can do before this step?
Message 4 of 8
Hey there @CHNLO, welcome to the BT Community Forums.
Is your Hub connected to a white Openreach branded modem that's attached to the wall with several lights on it, or is it just a traditional phone / broadband socket?
Feel free to post a photo if you're unsure.
If it's the latter, FTTP mode shouldn't be enabled, so this could explain the problem.
Peter
Anonymous
Not applicable
Message 5 of 8
If you have FTTP the LAN 4/WAN on the SH2 will be plugged into one of these or similar.
Message 6 of 8
Thanks it’s just a traditional socket, it’s not connected to a modem. I’ve turned off full fibre mode which also restarted the hub but unfortunately this doesn’t seem to have fixed the problem.
Message 7 of 8
Anonymous
Not applicable
Message 8 of 8
