Message 1 of 3
Re: Possible Home Essential Fibre 2 Speed Capped
Hi, I am having the same issues. I am on home essentials fibre 2 speeds are consistently 55down and 10up?
2 REPLIES 2
Message 2 of 3
Re: Home Essentials
Hi, I am having the same issue. I am on home essentials fibre 2 package speed are 55mb download and 10mb upload?
Message 3 of 3
I moved your post to start your own thread so you could get replies for your problem as previous one was marked as solved
Please don't post the same problem of different threads as just leads to confusion
 please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
can you check MYBT and see what it says for your broadband package either fibre 1 or 2?
Someone may then be able to offer help/assistance/suggestions to your problem
