Message 1 of 2
Re: Unable to send 'HELP' to 61998
It seems to be that number is BLOCKED by you phone as it is a PREMIUM cost number. I have BT call be about some work they had done and I mentioned it..  The guy says he was not aware but he it not in that team that use it...
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
This has come up a few times. The text numbers that BT use aren't premium numbers & are free to text from your call plan. But the type of number is one that typically is used for premium services. So in order to text BT, you have to have premium texts enabled on your phone & may also need to have an "out of plan" limit on your account set above zero.
