Anonymous
Not applicable
Message 1 of 16
Really?
Two years ago invested in a wifi 6 router to take full advantage of my BT 500mbps
For two years I basked in glorious speeds over wifi of often above 500mbps.
On the 5th September I signed up to plusnet 500mbps for £30 with a £150 gift card.
Start date being September 19th
After several calls to BT the best they could do was £40 to keep my custom.
My issue is not the renewal.
Since last week my once brilliant wifi has struggled to reach 200mbps.
Is this some sort of payback for leaving or just a coincidence that after 2 years of faultless performance it suddenly drops in the days upto my departure?
15 REPLIES 15
Message 2 of 16
Re: Really?
As WiFi speed is not governed by BT, how could they possibly have lowered it?
Perhaps your much vaunted WiFi6 isn't all it's cracked up to be!
Anonymous
Not applicable
Message 3 of 16
Re: Really?
Can I pick your brains Licquorice?
As you probably are sick of hearing I use a EE wifi 6 router with BT broadband.
As Plusnet are the same company will my switch over be seamless with me having nothing to adjust or does he Plusnet white SH2 have to be installed first?
Message 4 of 16
Re: Really?
Sorry, no idea. I have never used Plusnet.
I suspect it uses the same PPPoE credentials as BT, but can't confirm that
Anonymous
Not applicable
Message 5 of 16
Re: Really?
Thank you
Message 6 of 16
Re: Really?
As stared, how on earth do you think BT can influence your WiFi prefomance after you have left BT , it’s ridiculous, if you are receiving the correct line rate from PN , testing using a wired device, but the WiFi performance is not as good as it was , yet you are using the same router third party router  you had when with BT , whatever the issue is , it’s paranoid to think it could be  ‘BT’ interfering
Anonymous
Not applicable
Message 7 of 16
Re: Really?
I asked the librarian if she had any books on paranoia
She whispered
"they're right behind you"
Anonymous
Not applicable
Message 8 of 16
Re: Really?
@Anonymous
Plusnet use actual login credentials based on the username you chose when you sign up. So unless that router has a setting for credentials, you won't be able to use it.
Anonymous
Not applicable
Message 9 of 16
Re: Really?
Isn't the plusnet router just a white SH2?
Anonymous
Not applicable
Message 10 of 16
Re: Really?
Yes, but with different firmware to accommodate the login credentials. Plusnet has it's own systems that were acquired by BT, rather than just being a rebadged BT product.
You just need to look at the web interface of the EE router & see if it has fields for credentials.
