Message 1 of 2
Significantly Slow Speed to Device
Does anyone know why my BT app shows a download speed to hub of 935Mb, a speed to device for my phone of 381Mb (which I can live with), but then a speed to device for my PS5 of 7.9Mb? How can it physically be that low?
1 REPLY 1
Message 2 of 2
Re: Significantly Slow Speed to Device
@NiknotNahtanoj
There could be a whole number of factors at play. What WiFi channels are your phone and PS5 connecting to? The 2.4ghz channel has a longer range but a slower connection, whereas 5ghz channels generally have a faster connection but shorter range. Depends also on where your router is located in relation to what you’re trying to connect to.
Also, when did you last do a reboot on your router to clear the cache?
Same with your phone, if you do a full reset of your phone’s network settings, that can help speed things up.
As far as your PS5 goes, have you tried connecting it to your router directly using at least a Cat6 ethernet cable?
