Message 1 of 12
Slow upload on FTTP (900mb)
Hi,
I've recently had FTTP installed. The download speeds are ok, still not where I would expect them, but the upload speed is really bad.
Currently getting upload throughput of around 1.5mb and my upload profile is set to 115mb.
Anything I could try?
Regards,
William
11 REPLIES 11
Message 2 of 12
Re: Slow upload on FTTP (900mb)
@WilliamLow14
Are you testing the speed using a direct Ethernet connection between your computer and the BT Home Hub?
Wireless is no good to run this test.
Message 3 of 12
Hi Keith,
Yes direct connection via ethernet cable.
Message 4 of 12
I assume its the BT Smart Hub 2?
How long has your connection been activated?
Normally the default upload parameter is 20Mbs, until a change is sent to the home hub to alter it.
Your upload seems much lower, so initially I would try a full factory reset of the home hub, just in case there is an issue with the default configuration. Then test it again.
What speed does the BT app report?
https://www.bt.com/about-my-bt-app
Message 5 of 12
Yes new Smart Hub 2 connected.
The connection was activated yesterday (29th April).
The latest speed test was 328mb down and 2.54mb upload.
Regards,
William.
Message 6 of 12
Did you factory reset the home hub?
https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Is your computer capable of fast speeds and has a 1Gb network card, connected with a Cat5e or better, Ethernet cable?
Message 7 of 12
@WilliamLow14
Try a different speed test https://speedtest.btwholesale.com/
Select 500/1000mb option.
Message 8 of 12
Yes factory reset of the Smart Hub has been done with no improvement.
Yes the devices are capable of 1gb and are connected with a cat5e cable.
Message 9 of 12
@WilliamLow14
Leave it a couple of days to see if the upload speed improves once the profile on the Smart Hub 2 is updated
If its still the same, then a moderator can be asked to look at it.
Message 10 of 12
Ok Keith, I will do that.
Thanks for your help so far.
Regards,
William.
