Message 1 of 9
Smart Hub 2/Smart Hub 3 - lack of support from BT
I am afraid this is a somewhat long post but I do not know where to go to get this issue resolved, I keep getting promised support from BT but nothing materialises.
The problem started at the end of last year when by wifi speed from Smart Hub 2 dropped to 10 - 20 Mbps at a distance of 1 Metre away form the hub. Replacement hubs were sent with the same problem even using default hub settings with no devices connected. A total of 5 various engineers visited from both BT and Openreach and the problem was not resolved despite ethernet connection showing 950 Mbps. Eventually for no apparent reason the problem was suddenly resolved.
However last month the problem occurred again. Further conversations with BT could not resolve it and a new Smart Hub 2 was sent, this did not help. After further conversations BT sent a Smart Hub 3 which worked perfectly and I thought this was the way forward. The only problem was that the Smart Hub 2 Halo extender units did not wotk with Smart Hub 3. I contacted BT again and told them this and they said they will send some new extenders. These arrived but were for Smart Hub 2 and obviously did not work. Again in early June I contacted BT and spent hours on the phone explaining the situation and being transferred around different departments. Eventually someone said he understood the situation and would get the appropriate extenders sent. All that arrived was a bag to send the old kit back.
On 2nd July I again spent around 2 hours on the phone explaining the situation as no notes seem to be kept of any conversations. Eventually someone spoke to a manager in Accrington called Clara who authorised sending out extenders for Smart Hub 3.  Again all that arrived was a bag to send old kit back.
Despairingly I tried again yesterday and spent an hour on the phone. Eventually someone understood and got approval to send an EE extender out and I would receive order information last night.
Surprise surprise no order information received and no delivery information so it looks like the same route again.
Why does BT keep giving promises it has no intention of keeping? This is disgraceful customer service and my problem is not resolved.
Graham
[Mod edit: removed personal details]
8 REPLIES 8
Message 2 of 9
Re: Smart Hub 2/Smart Hub 3 - lack of support from BT
Hi @GJMAC
Thanks for sharing your experience with us.
I'm sorry to hear that this hasn't yet been resolved for you, and I appreciate the frustration of this going back and forth.
I'd advise calling the team directly if you've still not received any order or delivery confirmation, and they'll be able to help further.
Linzi
Message 3 of 9
It may be that they're waiting for the old equipment to be sent back - for testing or in general - and new to be despatched soon after. It's difficult to tell.
All is sure, though, that your WiFi problem is linked to your environment, especially if a number of BT hubs have not resolved the issue for you. I'd therefore start focussing on your environment to identify the issue.
In particular, older devices, devices that are not properly configured, or devices that have malware on them can be an issue. Additionally, WiFi congestion (on the same channel) may also be a problem. Finally, using a VPN style connection can slow down your connection, not to mention anything being streamed or downloaded in the background. Possibilities are endless. In my household, for example, the WiFi is lightning fast normally but someone in the neighbourhood has an electrical device (electric fire or blanket, as the issue mainly occurs in the winter) that slows down everything (through imposing noise on the mains) when it's on. Even though it was classed as SHINE by Openreach Chief Engineer's office when they came out here to do tests after 20+ Openreach engineer visits, it's difficult to eliminate and it can even affect you when you're on full fibre.
If course, the best way to test your connection is by using an ethernet connected device to confirm that the speeds you're getting are the speeds that you had signed up for. Then to have a methodological approach - by switching off everything that uses your connection and starting from scratch.
Without more details, it's difficult to tell.
Message 4 of 9
They are not waiting for old equipment to be returned, I have checked this. The BT system does not acknowledge that BT have sent me a smart hub 3 despite it being logged that they have sent it. On 4 occasions a manager has over ridden the system to enable smart hub 3 extenders to be sent out but it has not happened.
I have been through the route of disconnecting all devices from the hub and using default settings. I have tried new hubs and still the same problem.
I really have had enough of explaining the situation to BT in phone calls of about 2 hours a day.
Message 5 of 9
I am afraid I do not have the patience to go through this again with BT on the phone. Every conversation takes getting on for 2 hours and gets nowhere. Each person I speak to comes up with a different story. There is no way to speak to anyone who has any level of authority and there is no log of conversations to save having to go through the saga each time I call.
Message 6 of 9
As @Edinburgh-wg  has said, I would be extremely surprised if the fault lay with BT. I can't imagine that many devices having the same fault. As stated, the fault is extremely likely to be local interference possibly caused by a faulty appliance.
Message 7 of 9
Its quite surprising then that Smart Hub 3 resolves all the problems! Also using TP link devices configured in Wireless Access Point mode connected to the Smart Hub 2 work perfectly. Why the problems with smart Hub 2 internal wifi? BT are unable to resolve it!!
Message 8 of 9
I thought you said the SH3 DIDN'T resolve the problem.
Message 9 of 9
Sorry if that was the impression. Smart Hub 3 resolved the wifi problem and worked perfectly as a stand alone unit.
The issue was that BT would not supply extenders for the Smart Hub 3 to give me wifi coverage in my property which has solid walls and relatively large. This made it impossible to use the Smart Hub 3.
