Message 1 of 4
Smart Hub 3 upgrade from Smart Hub 2
Hi All,
I have fttp 900mb + and the smart hub 2 is failing terribly to transmit my 5ghz signal around the flat, is getting extremely hot and requires restarting now and again to work normally.
What would be the process for getting a smart hub 3 sent out to me as a replacement? I really want to make use of more modern WiFi-6 / smart channel scanning.
Any
3 REPLIES 3
Message 2 of 4
Re: Smart Hub 3 upgrade from Smart Hub 2
at present only new BT customers are getting the SH3 so as a replacement hub is required you would just get literally a replacement SH2
Message 3 of 4
Hi there, thanks for the reply.
Is this even if I've just renewed my contract? I know it isn't your decision but this seems like something that shouldn't exclude those who have been long standing loyal customers.
Time to investigate contract exit fees then.
Message 4 of 4
even just renewals didn't warrant a new SH3  if you have a new contract with 900mb then your ETC will be in the hundreds.  there is no leeway for long standing customers as has been shown many times on the forum
