Message 1 of 4
Smart Hub constantly showing orange disc lighting
I need some help regarding on the subject.
It started acting up 2 weeks ago and was getting poor connection regarding on bt logging i tried everything ranging from turning off https then back on, tried restarting both the modem and the hub still nothing to get a good connection and tried resetting them still nothing even got new hub still nothing.
Is anyone here able to help me get the good connection back?
3 REPLIES 3
Message 2 of 4
Re: Smart Hub constantly showing orange disc lighting
Report the fault to BT, nothing you can do
0330 1234 150
Message 3 of 4
Do you have a full fibre (FTTP) broadband service with an ONT (what you refer to as a modem) and then the Smarthub router, or do you have a part-fibre service (FTTC) in which the Smarthub acts as both modem and router?
Message 4 of 4
I have an fttp and the smarthub router
