Message 11 of 19
Re: Speed
Yes BT will be aware when checking the line and that is why they guarantee the minimum speed.
BT can not get you faster speeds than what your line can support and the distance from the cabinet is the biggest reason for speeds lower than the maximum speed of the package. That is due to physics and other than moving either the cabinet closer to you or you moving closer to the cabinet there is nothing that can be done about that unless you are able to get Fibre To The Premises (FTTP).
If it falls below the guaranteed speed BT will endeavour to rectify that and if they can not you are free to leave the contract without penalty.
Message 12 of 19
Re: Speed
You can put your address in or the UPRN.  UPRN is more accurate, I think.
You can find your UPRN here:
https://www.findmyaddress.co.uk/search
Message 13 of 19
Re: Speed
See chart regarding speed in relation to distance on a perfect line You will be VDSL2 which shows you should be getting somewhere about 45 Mbps if your line is perfect.
Message 14 of 19
Re: Speed
It is fiber 2 I am on and I get 45Mbs and it's not always that
Message 15 of 19
Re: Speed
Well, as gg30340 said then, it's primarily the distance.  This is why looking at that checker I posted is useful.  It will give you an idea of what the line is capable of.  If you are significantly below the minimum on there then you have a fault.
As I said, the big plus of FTTP (Full Fibre) is that it does not suffer from that problem and you get what it says on the tin.  I'd upgrade when you get the chance.
Message 16 of 19
Re: Speed
It’s not clear to me what your actual complaint is , but this explanation may cover it ,
Fibre 2 is a 80Mb service , that what the FTTC system on a short enough line will deliver, the advertising authorities didn’t like the ‘upto 80Mb’ advertising that used to exist so they said you have to use the figure an average customer gets , so BT  work out the speed an average BT customer on F2 gets  ,  and that comes out at 67Mb (that’s an average of all lines on BT F2 , short lines getting 80Mb and long lines getting 58Mb and everything in between )  ,so 67Mb  is what has to go on the advertising headline , but it’s pointless figure , if you live near your FTTC cabinet you probably get much better than 67Mb  , probably the full 80 Mb , that’s me , I’m only 120m away from my cabinet and get 80Mb , but the advertising still said 67Mb even for me  , if someone lives a long way away , they may get 56Mb , way less than the advertised 67Mb , but 67Mb is in the advert for them
That’s why BT also give you  a bespoke estimate based on your actual location, this speed is accurate for your address , the minimum speed guarantee generally is 10% lower , so if your  bespoke estimate is 65Mb , your minimum speed guarantee is around 58.5Mb , if you live near the cabinet , the bespoke estimate may be 80Mb , so the minimum speed guarantee is 72Mb , live very far away , and the bespoke estimate may be 50Mb the MSG is 45Mb ,  this is the figure to take notice of , you don’t need to care about the 67Mb average, you may not be an average distance from your cabinet.
You call it false advertising, but this is the  way the authorities demand speeds are advised, FTTC is what’s called ‘rate adaptive’ , it basically means longer line , slower speed , FTTP doesn’t suffer from this , the line length is irrelevant with full fibre .
Message 17 of 19
Re: Speed
@iniltous  While on the subject, could you answer a question for me please.  Is that guarantee figure what is meant on the checker by the "handback threshold" speed?
Message 18 of 19
Re: Speed
My understanding is they are not the same , but in reality they may only be a very slight difference between what the ISP gives as the MSG and the BTw/Openreach downstream handback threshold is , you should expect them to be effectively the same if they are not there probably is an issue.
The handback threshold is what the FTTC ‘system’ has the line syncing at , if (when checked ) it’s significant lower than the MSG the customer initially was given it could indicate a line fault , and if reported something for OR to look at , if the handover is higher than the ISP throughput and the customer complains to the ISP their speed is lower than expected or below MSG , it could be the ISP backhaul that is congested and not the line at fault ….so assuming no line fault and no ISP congestion both figures will be broadly similar, the MSG slightly lower to allow for overheads .
It shows why not reporting a line fault can cause issues later on , if a line is (for example) capable of 80Mb , the MSG/Handback both around 72-74Mb , but the line develops a fault , and the sync falls to 60Mb to stabilise the line but it’s never reported , over time the handback falls to the new reality of 60Mb , the MSG follows ,at the next renewal customer complains that the MSG is now only 50Mb when it used to be 70+ , if the line fault is removed , the sync and  handback increases back to where it once was , and the MSG follows ,  ISP bases their MSG on the handover threshold at the time the contract is struck .
Message 19 of 19
Re: Speed
Yes, I've never been sure if they were the same, as there seemed to be a discrepancy.  Thanks for that.
