Message 1 of 4
Super Slow Broad Band Speed
Hello, I have been having some major issues with downloading speeds. I'm currently getting 500 KB/s when I usually get 5 MB/s.
I've seen similar posts to what I'm currently experiencing so I'm going to ask for the same help.
Product name:Smart Hub
Serial number:+088047+1703003706
Firmware version:v0.12.02.01261-BT
Firmware updated:Thu Mar 21 21:49:38 2024
Board version:01
DSL uptime:0 days,02 Hours11 Mins47 Secs
Data rate:6.361 Mbps / 39.998 Mbps
Maximum data rate:6.361 Mbps / 39.888 Mbps
Noise margin:5.5 / 7.3
Line attenuation:26.2 / 25.8
Signal attenuation:26.2 / 23.4
Data sent / received:155.9 MB / 5.0 GB
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BTHub6-9H97
2.4 GHz wireless channel:Automatic (Smart Wireless)
5 GHz wireless network name:BTHub6-9H97
5 GHz wireless channel:Automatic (Smart Wireless)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:E0:51:63:32:AD:07
Software variant:-
Boot loader:0.1.6-BT (Fri Sep 9 10:05:09 2016)
if anyone can process this information and help out what is happening to my internet, it will be greatly appreciated.
3 REPLIES 3
Message 2 of 4
Re: Super Slow Broad Band Speed
from your stats posted your have 40/6.3 mb connection speed which is within range expected from dslchecker
can you try running fast.com  or   BTW Performance Tester (btwholesale.com)
must use ethernet connection not wifi and post results
Message 3 of 4
Here are my results.
Today seems to be a good day as I'm reinstalling apex and I'm averaging 4-5 MB/s on steam, but last night I was getting 500 KB/s.
Message 4 of 4
I wonder if you are getting confused between MB/s and Mb/s. Your speeds as you reported are spot on. 4-5MB/s = 32-40 Mb/s.
Internet speeds are expessed in bits/second. Downloads in Bytes/second. There are 8 bits in a Byte.
As regards steam do you know the sever load at the time? It is not an indicator of your connection speeds at all.
