Message 1 of 4
Swapping to BT/EE. What does "1 stage" mean for FTTP installation?
Hi
I'm moving from Virgin Media after 20+ years and currently waiting for engineer next week. There isn't any telegraph poles nearby as far as I'm aware so surely the CBT must be underground somewhere? It says my premise is eligible for FTTP openreach as it wouldn't let me order otherwise and when I check with BT's address checker I get these results.
It says FTTP is available but then also says No for Priority Exchange?
I guess my questions are:
What does FTTP Priority Exchange: N mean?
What does FTTP install process 1 stage usually mean, will I need my front garden/back garden dug up?
Kind Regards
3 REPLIES 3
Message 2 of 4
Re: Swapping to BT/EE. What does "1 stage" mean for FTTP installation?
Single stage means Openreach expect to get your service in with a single visit , somewhat strangely though that’s not the norm when the survey notice states a potential problem ‘congested duct’.
From the early 1990’s the standard BT ( as it was then ) service method for houses was a fully ducted route  so if your house was built after then , there will be a duct , but there was something that caused the surveyor to indicate a potential problem…if your house was build in the 1960’s up-to  the early 1990’s , its an underground service but not fully ducted method, in those cases excavation is to be expected but the surveyor note is different, it would say ‘partial DIG’ , but it’s possible the surveyor has used congested duct incorrectly, or there has been a change in policy to use that survey marker ( I’m not as upto date as I once was )
No need to get hung up on priority exchange, that’s just where copper products can be ordered at all , as FTTP is available and is the default once it is available, it’s an irrelevance.
Most underground services are from the front , from joint boxes  in the footpath , excavating may be necessary should the existing duct be blocked but they would obviously ask before digging in your land , if the blockage was in the footpath, they obviously dont need your permission but there is no need to worry until it’s established if the duct is OK or not , it’s only a suspicion that its ‘congested’
Message 3 of 4
Thanks for your reply.
I believe the house was built in the early 90s, we are the second occupants. We do have an old wire that comes into the house from somewhere but I believe that was for an old, old CRT TV so probably irrelevant.
All we have on our front walkway is a drain and a chamber that says Ductile Stanton PLC H Warrior/ Thames water related. The ground is all bricked. We do have [or used to have] a grass area to the side which has now already been dug up to grow flowers so hoping the ducting is there if anything will probably cause the least amount of issues if digging is necessary.
Message 4 of 4
Most BT/Openreach  duct appears on an external wall and is visible because of the grey plastic parts used  , a BT connector bend no.4 , capping 25 and a cover 101a or BT66 , search for images if you want to see what these look like ……if your address is fully ducted these would have been used but if there is no evidence of the duct appearing on the wall ( usually signified by these grey plastic parts attached to the exterior wall ) it may explain why the survey note was ‘congested duct’ as there is no confirmation ( in other words nothing visible ) of the duct  ….most developers followed the guidance by BT or Openreach depending on when the house was built and had the duct appear on an exterior wall , some may have  , for aesthetic purposes brought the duct inside , in a garage for example…early 90’s is right on the changeover from buried armoured cable to duct so it may be no duct exists in which case excavation will be needed, if it is armoured cable , it should really be KCI2 ( two stage ) and partial DIG (direct in ground ) as the survey note , it’s difficult to tell without knowing the area etc.
