Message 1 of 6
Telegraph pole installation
Open Reach need to install a telegraph pole near my garden wall, will the guarantee to repair any damage to the wall or its foundations ?
5 REPLIES 5
Message 2 of 6
Re: Telegraph pole installation
You would need to ask Openreach that. This is a BT retail forum,nothing to do with Openreach.
Message 3 of 6
My contract is with BT. Open Reach web site advises to contact service provider ..BT
Message 4 of 6
BT retail won't provide any guarantees regarding infrastructure provided by Openreach. They have no control over Openreach employees and works practices.
Message 5 of 6
https://www.openreach.com/help-and-support/when-to-get-in-touch-with-openreach
"Something else
The quickest way to get in contact is to use our virtual assistant.  Eiva will help you to find the information you need or set up a chat with our customer services team if necessary. Just click on the icon in the bottom right corner of the screen to get started and select the option for ‘others’ and then select ‘contact us’ to get started."
Message 6 of 6
If you have ordered ‘new’ service yourself , and it’s necessary for a new pole to be placed on your property to provide your service, and the chosen location is near your wall , then the provider you have used ( BT ) have no responsibility for their supplier’s equipment ( Openreach ) , but you would have been consulted by OR about its location , if it we’re serving your property was  to be sited on your  ‘land’ for that purpose.
Its much more likely the pole is nothing to do with your existing service, and is being placed in a public area ( public footpath or verge the most likely place ) so OR  have no need to advise you individually , although a pre- pole notice may have alerted you to its impending deployment .
If you are simply a concerned member of the public because you have seen the pre pole notice , and the pole is going to be near to a wall you own , the fact that you personally use BT as your supplier for broadband or telephone is irrelevant , it’s not going to be on your property, and for all you know the reason for the new pole may be driven by another providers customer ( like Sky or Talk Talk and not BT ) or it could simply be part of OR’s network expansion ( lots of new poles going up with the rollout of FTTP) so basically absolutely nothing to do with BT or any other service provider.
In the unlikely event that your wall is damaged by the installation of the pole , then OR are responsible for any restorative work , (should you need to report your wall as being damaged by the installation) but until it’s installed why assume the wall will be damaged ?, it almost certainly won’t be.
