Message 1 of 5
The chaps installed the equipment on the telegraph pole
Do I need to apply/sign up or do I just be patient and wait until the next stage of installation, from the pole to my home?
4 REPLIES 4
Message 2 of 5
Re: The chaps installed the equipment on the telegraph pole
If your area now has Openreach  FTTP , ( the new equipment on the pole you presume signifies this availability ) then you apply to have it connected, either by being proactive ( you calling BT ) or when re-contracting and being advised that it’s a condition of the new contract ,  if you do nothing , nothing will happen.
Its possible that in the future ( maybe 5-10 years ) that BT customers will be told, move to FTTP or lose your existing service, but that’s way off , in the meantime, if you want FTTP you will need to ask for it .
Message 3 of 5
Yes, I am fairly sure, I spoke to the engineer who said it's equipment to prepare for FTTP.
Thanks for the advice, I will get in touch with BT. I think I'm out of contract, not sure if that changes much but their online checker says I don't have Full Fibre availability, yet, I assume it's not be updated or activated? Only issue is other providers who must use the same checker can't see it as available either.
Patience and a phone call I guess 🙂
Message 4 of 5
The period from having the CBT installed on the pole and the service being available to order can vary , and there needs to be testing commissioning once the optical path is completed, the ‘downstream’ optical path to the Aggregation Node may or may not be complete …individual ISP will have no knowledge of this , period , from their point of view it’s either available to order or it isn’t , and they don’t know if it will  be available in a week , a month or months , best to keep checking yourself.
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
This is a good place to keep an eye on progress ,
Message 5 of 5
Thank you Distinguished Guru 🙂
