Message 1 of 6
Third party routers for FTTC connections.
Does openreach require you to use a router with a broadcom chip only?
Does this router compatible with openreach  Asus DSL-ax82u
Also do we need to have bitswap on on third party routers?
5 REPLIES 5
Message 2 of 6
Re: Third party routers for FTTC connections.
No, yes, yes
Message 3 of 6
I have been told by other vdsl gurus that openreach expect broadcomchips which is why broadcomchips are in all vdsl routers such as sky and bt.
Message 4 of 6
They are telling you nonsense.
If you are not going to listen to the answer, don't ask the question.
Message 5 of 6
okay
Message 6 of 6
Openreach still have ECI/ lantiq cabs is service and they usually pair up slightly better with a lantiq modem however.... The difference is minimal slightly lower error rates with older BT home hubs like the 5a.
You won't likely notice the difference, unless you watch the DSL link stats like a hawk.
