Message 1 of 11
Trying to report a fault
Monday 21st July swapped from copper to FTTP by Openreach on behalf , this is because of Digital Voice
Wednesday 23 July Internet dropped out three times the 3rd time it stayed off,
Contacted BT Via 150, who said i needed a patch lead with RED PLUGS? (this is now fitted) but system is still down.
Had a call back from BT Guide on Friday to check if all ok (No It is not)
An Engineer CIRTEC in HOME ENGINEER? was booked to attend WED 30TH July, At the same time I was told my Fault was due to a MAJOR OUTAGE in my locality , 2 near neighbours also on BT Fibre (fed from same pole as me)are working fine so this is false information.
Spoke to a BT Guide SAT 26TH and went again through all the issues about red plugs, major outages etc etc and he has now raised a fault with OPENREACH as  urgent .
QUESTION WHY IS SO HARD TO GET ANYONE TO UNDERSTAND YOUR SYSTEM IS BROKE (I do have limited Internet via aN EE HALO WHICH IS SLOW BUT GIVES ME ACCESS
10 REPLIES 10
Message 2 of 11
Re: Trying to report a fault
First of all you don't need FTTP for Digital Voice, but that's not relevant to the problem.
Also the colour of the cable is entirely irrelevant, it is just an Ethernet patch lead.
What are the colours of the lights on the ONT (optical modem) and the smart hub?
Have you connected the ONT to port 4 on the hub and is the hub configured as full fibre mode?
Message 3 of 11
It may be a fault affecting many users ( so you may be repaired as a consequence of Openreach fixing that common fault regardless of you actually reporting your issue ) or you may have an individual failure.
FWIW , if a failure is to happen, it’s usually quite soon after installation ( its relatively common ) , as stated the most informative thing you can confirm is the status of the ONT , if the LOS light is lit , Loss of Signal , then there is a physical issue , if the PON light is lit but flashing it’s an authentication issue , if the ONT lights are normal (PON light steady green ) the OR network is fine and it’s a BT issue , possibly account related ….the colour of the plug on an Ethernet cable is irrelevant, the ones with red plugs were to supplied to make self installs foolproof, red plug into red socket ….the router no longer has a red socket so supplying a red plug Ethernet cable is pointless these days .
Message 4 of 11
I now know the patch lead colour is irrevelant, why do BT  make such a deal of it, land-line now plugs into Smart Hub so no Internet no lanline,Hub is configured to Fibre, white modem has 3 green lights all steady bar for RH gives a small pulse, Smart Hub is steady purple this is because Halo has me connected via EE 4g
Message 5 of 11
So
Power on Green
LOS no light
PON Light Green
LAN Light Green with small pulse
Why would it be an account issue ? have I been switched off by an accountant? How do I sort it?
Message 6 of 11
If the ONT lights are normal , then there is no problem with the Openreach network, I’d check  the connection  between the hub and the ONT is satisfactory, presumably you have already checked  that the hub is set to full fibre mode and that ONT is connected to the 4th Ethernet socket  (actually a WAN socket when full fibre mode is selected)  , also  consider changing the Ethernet cable if not already done so.
If it is an account issue , ( if the hybrid connect wasn’t available you would expect the hub to flash purple ) …it’s also worth power cycling the ONT and router , it may be the FTTP service is back on line  but the hybrid connect  hasn’t handed back the service to the FTTP
Message 7 of 11
O and it cannot be a major fault as my near neighbours also BT Fibre are not affected
Message 8 of 11
I’d agree it unlikely to be MSO if your near neighbours are not affected ,
the ONT status shows the Openreach network is fine ,it seems it’s  from the headend into BT as the ISP ( so your account )  to be where the issue is , this us assuming the  situation continues after you have reset both the router and ONT
Message 9 of 11
Disconnect the Hybrid device.
If the hub stays purple it is a physical fault between ONT and hub, if the hub turns orange it is an account problem.
With the initial intermittent nature of the fault I suspect the former.
Message 10 of 11
So because I have all 3 green lights on ONT Modem , can I assume then the patch lead is not connecting inside the modem . the steady purple indcates I  am connected by an EE Hybrid device this is part of the halo 3 package with BT
