Message 1 of 2
Unable to connect to client Website (IP Blocked?)
Hi,
I'm currently building a site for a client which is hosted on GoDaddy. In the last couple of days I've been unable to connect (timing out). After a long session trying to contact GoDaddy I gave them a traceroute to the website in question and they suggest that the IP of the host server is being blocked by my ISP (BT).
I'm using the BT SmartHub (Fibre Broadband (VDSL)). Is anyone able to suggest the best way to get this resolved? Or, do I need to go through technical support?
1 REPLY 1
Message 2 of 2
Re: Unable to connect to client Website (IP Blocked?)
Actually, soon after posting this I found that rebooting my SmartHub/Router did the trick. I guess this resets the (DHCP) IP address, hence why it worked.
Anyway, though I'd post an update in case anyone has a similar issue.
