Message 1 of 7
Upgrade from FF100 to FF900
Hi folks,
I've just signed up for the above mentioned, do you know if there is a break in service during the switch?
Important meetings tomorrow when its due to kick in.
6 REPLIES 6
Message 2 of 7
Re: Upgrade from FF100 to FF900
if you are currently on FTTP then the change will call the hub to restart but should not be any downtime apart from time it takes hub to restart
Message 3 of 7
Will that be a manual restart or auto when upgrade kicks in?
Message 4 of 7
I would expect it to be auto as your profile is changed from FTTP 100 to 900
Message 5 of 7
One last quick one from me.....
Is the time random? Or do they have a set time, say midnight on the specified day?
Message 6 of 7
No specifc time, just should be before midnight.
Message 7 of 7
Perfect, thanks for your help!
