Message 1 of 6
Upgrade not good - need help
Our contract recently expired and I got a letter with my options - the package we were on no longer exists so opted for Halo 3 hybrid which is basically same price as what we were paying before.  Received the hybrid EE thing and a wifi disc, all connected up no issues - except our speed is awful!  The EE hybrid only gets one bar signal no matter where I put it, so hope I never have to rely on that!!  My PC has no wifi so is connected to the wifi disc with ethernet cable - and lucky to get 200 mps download.  The BT app says "speed guarantee not reached" and indicates more tests required - click that and the next screen says "test not supported" so not sure where to go from here.  The app tried twice to reset my router and failed both times. Eventually got connection back and its even worse than before.
After sitting in online chat for over an hour the other day to get another 2 wifi discs for other 2 PCs in the house - they sent one with promise of another when in stock (sigh).  I'm really not keen to go through that process again since the guy said "I've tweaked your hub and it should all be good now" and since then its been frankly terrible.  Had great success in the past with the forum moderators here so hoping someone can help me out please??
5 REPLIES 5
Message 2 of 6
Re: Upgrade not good - need help
I understand the frustration, but it sounds like you're on the right track with troubleshooting. Since you've had success with forum moderators before, I'm confident they can help resolve the issue quickly and get your connection back to normal!
Message 3 of 6
unfortunately the forum mods no longer have account access so you will need to continue with CS 03301234150
Message 4 of 6
"I'm really not keen to go through that process again since the guy said "I've tweaked your hub and it should all be good now"
AFAIK, I don't think a telephone agent can do any "tweaking" of your hub - all he/she can do is reboot it - which you can do yourself. I don't think it is even possible to do a factory reset remotely - that requires pressing and holding in the small button on the back of the hub.
So the agent was just giving you b*llsh*t!
Message 5 of 6
Oh no that's not good news 😞 Thanks for the reply though
Message 6 of 6
I have been experiencing a similar intermittent issue for 20 months. I had consistently been told that my problem was internal and was even persuaded to upgrade my “Full Fibre 900” package, to include “BT Halo 3”. Needless to say that this did not resolve the problem and BT have finally admitted, that there is a known software issue with the mechanisms that they employ, to measure the incoming signal to the ONT. This has been referred to as a “Stale PPP Session Fault”, which effectively means that “hereditary” and not “live” signals can sometimes be recorded. The bottom line is that their own remote tests and those carried out at the premises by “Openreach” engineers, are not as infallible as they claim, as they can result in “false positive” results. BT have consistently refused to accept the evidence supplied via the “MyBT App”, that my service has fallen below their “Stay Fast Guarantee”, on 259 separate days since April 2023. However, they will accept the results taken via the “https://pbtcsc.saas.nokia - Hub Smart Speed Test”, which you can request from customer support. The issue with this test is that it has a short shelf life of only 24 hours, so must be requested on a daily basis, which is time consuming. On a positive note and from my perspective, BT have consistently implied that I am the only one of their 10+ million “Full Fibre” clients, who has experienced this issue, but this is clearly not the case. Good luck.
