Message 11 of 16
Re: Upgrading FTTC to FTTP and old Smart Hub 2 to 'new' Smart Hub 2
@Mr_Incredible
How does you copper connection come into the house, overhead or underground?
Message 12 of 16
"How does you copper connection come into the house, overhead or underground?"
Overhead.
Message 13 of 16
"if you go to MYBT what does your order confirmation show is being done?"
https://i.imgur.com/GkF9Bf2.png
Message 14 of 16
@imjolly   Did the screenshot of the order shed any light for you?!  Thanks,
Message 15 of 16
normally now when you upgrade to FTTP you also get changed to digital voice but can't see anything about that unless you already have DV
Message 16 of 16
I don't have DV and was told that getting DV would mean having to lose my current landline number which I have had for donkeys' years. I said I wanted to keep the number. Hence AFAICT, they will run the copper line alongside the Fibre so I can. For now at least. Perhaps when there is no option and I have to go DV, that they will have figured out how I can keep my number.
