Message 11 of 17
Re: Upgrading contract
Good idea - will a EE router work on a bt fibre Contract ?
Message 12 of 17
Thanks - good idea -
I’m Will a EE router work on a bt fiber contract ?
Message 13 of 17
yes
Message 14 of 17
Yes, otherwise I would not have suggested it.
Message 15 of 17
Thanks for your advice - can you tell me should I get
a SH32b or Sh31B please
I have fttp
Thank you
Anonymous
Not applicable
Message 16 of 17
Might be best asking that question on the EE community.
Message 17 of 17
I have fttp
Thank you
The 32b is the latest one so it may be the better one but I do not know any of the specs about them or how they perform so it may be best to do as suggested and ask on the EE Forum. https://community.ee.co.uk/
