Message 1 of 24
Upload speed is awful / painfully slow (667kbps)
i have FTTC and live in a rural spot 1 mile from the cabinet...so appreciate its never gonna be fast (frustratingly)
i get circa 20-25mbps Download
But Upload is awful - takes ages for example to upload a PPT in work....didnt use to be this bad when i was with Vfone and Plusnet etc
Extract from the Hub Manager page (192.168 etc):
Downstream sync speed: 20.147 Mbps
Upstream sync speed: 667 Kbps
Can this be right?  in keeping with 20mb download?
Do i need to call Tech support ?   (i fear doing this as i will get asked all the same daft questions about my router, wire etc)
Many Thanks!
23 REPLIES 23
Message 2 of 24
Re: Upload speed is awful / painfully slow (667kbps)
I think a chat with technical support is worth the effort, yes I am sure there will be some questions about the set up and whats been done but that won't take long they can then identify if there are any issues and investigate further.  Whilst there are plenty of things that can effect this, wired connection vs wireless and how many devices are on the network its worth an investigate
Message 3 of 24
Product code:Hub
Serial number:+091298+2425012963
Firmware version:v0.45.00.08028-BT
Firmware updated:Fri Apr 18 01:35:40 2025
Board version:R01
GUI version:1.80 11_07_2023
DSL uptime:0 days,11 Hours26 Mins34 Secs
Data rate:667 Kbps / 20.147 Mbps
Maximum data rate:667 Kbps / 21.256 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:6.0 / 4.7
Line attenuation:25.2 / 37.7
Signal attenuation:20.4 / 45.5
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:1.1 GB Uploaded / 6.9 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-29FJK6
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:BT-29FJK6
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:34:19:4D:4C:F0:CE
Software variant:-
Boot loader: 0.1.7-BT
Message 4 of 24
the copper line to my house is awful - over 25 years and 100% of the issues we have had is resolved by Open Reach coming to replace line or fix the line etc.   We have had several faults this year resulting in them patching up the line
So my strong suspicion is its the line....
What kinda speeds should i expect for 20mbps download?
Message 5 of 24
My FTTC upload speed runs at about 1/4 of the download speed, so you should probably expect to get around 5Mbps upload.
Message 6 of 24
Why is your router set to Full Fibre (FTTP) Mode:On when you have FTTC?
Message 7 of 24
@JonUK wrote:
It doesn't matter, all it does is change port 4 from LAN to WAN
Message 8 of 24
Router is default - i didnt edit that!  (FTTP)
i am using TP link Deco mesh, but (i) those numbers are from the router (ii) download and upload is same if i connect via LAN cable to the router direct.
Message 9 of 24
Can you enter your address and post results to see what it shows as expected connection speed for your line.  Please add the notes as well.  https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
Message 10 of 24
Thanks IMJolly
