Message 1 of 17
Varying speed test results
Hi - just had Full Fibre 900 installed today.  The engineer told me it could take 10 days for service to stabilise and for the speed also to stabilise.
In any case, I thought I'd test.  Using Ookla, I get 90mbps download; using the BT speed checker (browser), I get the same.  And in the BT app, I get 795mbps download.
I'm not sure which one to believe, should there be such a variance between speed checkers?  If 90mbps is my download speed, then on day one, should it be higher than that - could it increase so dramatically in the next 10 days?
Many thanks.
16 REPLIES 16
Message 2 of 17
Re: Varying speed test results
The only reliable way you will know what speeds you are attaining, is to plug your phone or laptop or desktop PC (adapters are readily available from Amazon etc) via an ethernet cable directly into your router. There's no point relying on the speeds via WiFi. I'm assuming that you are using WiFi? I also assume here that you are now FTTP?
In any case, try using fast.com as the speed checker.
Also, when I had both my 500mbps broadband through FTTP connected both to BT and then Plusnet, I got 500mbps download and 75mbps upload from day one. There was no 'settling in' period.
Message 3 of 17
Hi - yes FTTP and I already tried connecting my MacBook to the SH2 and disabled Wi-Fi on the computer.  Connection speed was also about 90mbps.
The BT checker here: https://www.bt.com/broadband/check-your-broadband-speed - does use Fast.
Maybe I'll leave it a few days and see what happens - thank you.
Message 4 of 17
There isn’t a settling in period , that’s just wrong , what device are you using to measure speed (laptop , desktop , tablet ? ) and is it using a wired Ethernet  connection or WiFi ?
If it’s a desktop / laptop and wired , I’d check / replace the Ethernet cable first  for a Cat 5e or better , and if the device is getting on a bit , check its Gb capable as it may not be , and it’s configured correctly. if you are using WiFi  ,that’s not something your provider can guarantee, the BT checker is speed to the hub , hence the expected speed as it’s not hub to device which clearly is beyond the control of your provider.
Finally , 90 MB , 90 Mb , 90 mb are not the same thing , 90 MB is 720Mb , but that’s still low for a 900 Mb connection if using a capable device on a wired connection.
Message 5 of 17
On my system, my Ethernet cables are nothing less than Cat6. I'd highly recommend ditching the Cat5e cables for Cat6 but some may say otherwise.
Message 6 of 17
The speed you are paying for should be delivered on day one. FTTP does not take time to settle in.
When you measure the speed you should use the BT speed tester as given in the BT App as it measures the speed to the BT hub which is the speed that BT use to give your Stay Fast Guarantee.
The other speed testers only give the speed to your device which can vary depending on whether it is being done by wireless or Ethernet as well as the capability of your devices network cards but having said that there should not be a such a massive difference that you are showing.
Openreach use Fast.com to check the speed when it is first installed so try using that and post the results.
Anonymous
Not applicable
Message 7 of 17
When the Openreach installer says it needs time to settle that's just the code for "you're done and I'm off"
Bit confused though if you had it installed today why you weren't given the new smart hub 3.
I won't go into anymore detail as this topic has literally been covered hundreds of times.
Just type your query in the "ask here" box and you'll discover a really well covered subject
Message 8 of 17
Thanks - I am using wired ethernet into the SH2.  Using a MacBook Air (new this year) with a Cat5e cable.  Fast.com is saying:  91mbps download and 90mbps upload.  I have tried two different Cat5e cables, same results.  Same when I use my phone with the ethernet cable.
Bizarrely when I connect to Fast.com on my iPhone over wifi, I get 300mbps.  And the BT checker in the MyBT app over wifi says 820mbps.
It's surely not normal that a wired connection should be slower than a wifi connection?
Message 9 of 17
@Anonymous  I admire your cynicism, you're almost as bad as me.
As for the SH2, I suspect the customer already had the SH2? Can't see BT just handing out brand new SH3's if they've perhaps still got thousands of SH2's lurking around in BT vans still waiting to be palmed off onto customers.
Message 10 of 17
@DWDKHN
As I already explained. The BT App gives you the speed to the hub. This is not the speed over wifi even although you are using wifi in order to initiate the test.
I don't have a MacBook so I can not advise how to do this but you should check that its network drivers are up to date.
I would also try a factory reset of your BT hub if it has not been done since your FTTP installation.
