Message 1 of 14
When is 1.6gbps and WiFi 7 coming to BT
Does anybody know when 1.6gbps and a WiFi 7 capable router is coming to BT? If it is not can we transfer to EE 1.6gbps yet?
Tags (3)
13 REPLIES 13
Message 2 of 14
Re: When is 1.6gbps and WiFi 7 coming to BT
Hi @mike63uk
Get up to 1.6Gbps and connect up to 190 devices at once, when you switch to EE.
Login with your BT account for your best deals and to find out more at Migrate from BT to EE | Broadband
Ali
Anonymous
Not applicable
Message 3 of 14
@Ali_A migrating to EE from BT will this  do away £30 actvation charge ?
Message 4 of 14
@Anonymous  Haven't you already asked this question and been given the answer?
https://community.bt.com/t5/Bills-Packages/Activation-Fees-for-new-customers/td-p/2467304
Message 5 of 14
Hi @Anonymous
As long as it's ordered/performed as a re-grade migration, not a new connection, there is no activation fee charged when migrating a service from BT to EE  😀
Ali
Message 6 of 14
Be careful though as billing is automated and if you're still in contract with BT then you'll get a early termination charge
P.S
1.6 gpbs is just silly
Message 7 of 14
Enough to run a small country not so long ago 😀
Message 8 of 14
Absolute rubbish, if transfer is done following correct process no charges are applied at all
Anonymous
Not applicable
Message 9 of 14
ive done this at least 5 tmes over the years with differnt providers
the only thing i had was when a previous provider kept billing me after i supplied proof id actually left the had refunded me and closed my account this was years ago tho
Anonymous
Not applicable
Message 10 of 14
yeah if your still in contract yes but first thing i do in this case is check when my end date is if you get charged etf thats not on the isp at all if you forget or dont check this
