Message 4 of 13
Wifi box changes from Blue to orange and purple
My wifi box has stayed on the colour blue for a bit and currently now changes from orange/purple to going back to blue for a bit and then repeats the whole process
how can I fix this my broadband had also just been activated today but bt also has said that it may take a couple days for it to be at its best
12 REPLIES 12
Message 1 of 13
BT wifi router flashing purple and orange
Hi hello I really need help with my bt wifi router as it has kept on flashing orange and purple although I have gotten my activation message 20 minutes ago.
do I wait until midnight or is there a problem with my set up
Message 2 of 13
Re: BT wifi router flashing purple and orange
See link about what the lights mean
What do the lights on my BT Hub mean? | BT Help
Message 3 of 13
It says purple means there is a broadband problem and flashing orange means trying to find the internet but everything is set up right
Message 5 of 13
Re: Wifi box changes from Blue to orange and purple
By 'wifi box' I assume you mean the BT hub. If activation is today then it can take up to midnight to happen so try tomorrow and if no change then post back
Message 6 of 13
My bad yeah I meant the bt hub and do I have to wait till tomorrow until the wifi hub stays at a stable blue colour cause even now it keeps fluctuating
Message 7 of 13
It's obvious you are not getting a good connection.  You can try a factory reset by pressing the recessed button on back and holding till lights flash and see if that makes a difference.
Activation can take until midnight to actually happen
Message 8 of 13
Re: Wifi box changes from Blue to orange and purple is
Alright I’m going to try reset the wifi hub
Anonymous
Not applicable
Message 9 of 13
Is this a first time connection or have you switched from another ISP? If the latter then I'd put the old router back & see if that still works. If it does you know the switch hasn't completed.
Message 10 of 13
This isn’t the first time no
I changed from sky to bt so the old router won’t connect to the internet either but I plan to call bt tomorrow and hopefully it should be fixed then because as stated above I already got the notice of activation at around 6:12pm but the lights keeps flickering from blue to orange/pink
